I couldn’t find any springs stiffer than the V4 Talion comes with... R Talion springs in the front & R V4 Kraton springs in the rear really raises the ride height. I got the idea from this members buildInstead of swapping things around and using springs from other vehicles, isn't it easier to buy a proper set for the Talion, just up the stiffness a bit more?
I tried. Maxed out the collars, added 100wt oil...Instead of swapping things around and using springs from other vehicles, isn't it easier to buy a proper set for the Talion, just up the stiffness a bit more?
Tossed in the Mojave fronts. Much better!! View attachment 109355View attachment 109356View attachment 109357
Mojave ones a tad longer
Yes. I left them and cranked the collars down 1/4” and now has 80wt oil. That’s 100 in front and 80 in rear. She rides like a dream w the big block now.And the stock Talion springs in the rear?
I’m sorry I said it wrong. I used the Mojave front shock which is longer w the talion coil.List of springs is below.
I use the Nero/Big Rock in the front (AR330347), stock Talion V4 in the rear.
Mojave springs have less force, not sure why you want less.
https://www.arrmaforum.com/threads/...or-4s-and-most-6s-vehicles.18704/#post-286478
Hmm yea, well I just wanted to stiffen everything up a bit so it didn't bottom out so easily, or sag so close to the ground just under normal running conditions... so wanted to stiffen up whilst still maintaining good articulation - now it seems I've stiffened things up but lost that articulation, it's more of a bounce now (especially in the rear).You should first think of what you are trying to do. Springs are for weight, and transfer of weight. They will impact how the suspension reacts to terrain, especially when going to extremes, but you really want to rely on dampening to control terrain and jump handling. If it bottoms out easily, increase oil weight and/or go for smaller or less holes in the pistons. Stiffer springs will also impact how it bottoms out, but can also result in poorer rough terrain handling. In my opinion, you want to use springs that support the weight of the vehicle, but not impact how the suspension handles rough terrain.
Now...if you are wanting to stiffen things up for better on road handling, that is a different story.
