Talion Talion Beefed Up Pros / Cons
northeastflyer
live free or die
  2. Talion
One of the big differences in my kraton and talion is the weight. I am attracted to putting in the same m2c and HR upgrades but worry I will compromise on what makes a talion a talion.
Currently I have the m2c chassis braces and have hr hubs en route.
That said - I guess I have to decide if I want to drive the Talion like a basher or a racer. I drive the kraton like a basher so the heavy parts are wonderful.
Exactly! i like my Talion light and nimble. even moving to just heavier tires is ruining the Talion-ness.
I say, assuming that the EXB chassis is the same weight as the stock, maybe consider using it instead of the 4mm m2c?
Exa
exactly what I was thinking. To keep weight down I’ll probably end up getting the 3mm exb chassis for the talion. Keeping weight down has been a huge concern of mine so I’m probably only gonna upgrade what’s necessary. Ordered some backflip lp’s the other day so I’ll test those on the talion .
Exa
i have them
on now and like them. id like to order another set but cant find any.
I am in the same spot as you guys. I tried the HS 1730 but it totally changed the handling and slowed it down ,even gearing up. I’m thinking about a hobbywing 4274 2200kv what do y’all think ?
If your talion is gonna get aluminum upgrades down the road, don’t get the 2200kv. In my opinion that motor is more for buggy’s. It heats up real quick.
I have the Castle 2200 KV in my Talion and BigTim is right. I overheat the motor in probably about 6-7 minutes, maybe less. I wanted to gear up to the 20 tooth, so I had to turn the EXP down to 75% on my remote. Running on 6s, the 2200 KV motors over rev at max power. To keep temps down to safe without a fan ( I hate extra wires for the fans), I had to keep RPM's peaking at 40K. So 75% of my power output. As the voltage drops you can probably turn the ESP back up, but it's truly a waste of time. I love my HobbyStar 1730 KV geared up to 22 tooth. I still get to around 70, no GPS. And it is no where close to overheating, torque is off the charts as always. I run the stock Katars most of the time. When I need more grip, I have Backflips, which offer sick performance in grass and loose dirt.
I built my Talion at first to be light weight and nimble. Then I added M2C chassis, braces and a max6 4985 combo and noticed the weight getting up there and it’s nimbleness declining.
Long story short, I ended up pulling the max6 combo out of it and putting the stock electronics back in it along with the original katars to get it back where I thought the handling should be.
20t pinion /46t spur along with 30/500k/60k and it’s perfection IMO.
Besides my 120mph Typhon nothing in the fleet can touch it in the corner carving department
I’m running same setup as @Mr.Duke. And imo too it’s perfect
View attachment 88752View attachment 88753
How’d you get no overheating issues with that gearing?. My talion got hot with stock katars and stock diff fluid and 13/50 gearing.
I run (2) 30mm fans on the motor and temps are usually 150-155 with 85f temps outside after a full 6s pack
I just took one of those out of my talion cause it was having issues with its stock weight. I would nail the trigger and it would hesitate (no it was not the radio, I have a futaba) i just feel like it needed longer to wind up. I put a 1600kv 4082 in there with a max8 and a 20T pinion... it rips... and the shorter 4082 isn’t too heavy so it (in my opinion) didn’t throw it off too bad. I also run backflip LP’s on my talion.. ??‍♂️ I dig the setup tho.
Sure does, mine got to 180 just after a few minutes.. and it works phenomenal in my typhon tho.. ??
Right now I’m back to stock motor and Max6 with all aluminum upgrades. I guess that’s about as good as it gets. I was looking for 70 and bashing with same pinion AND no weight gain. If someone figures it out let me know ??‍♂️
