calebgilmore
- Granite
- Infraction
- Kraton 8S
- Kraton 6s
- Mojave
- Notorious
- Outcast 6s
- Senton 6s
- Talion
- Typhon 6s
- Vorteks
- Voltage
Arrma makes a 46t spur, and you can get some smaller tooth ones on ebay but i'm a little cautious to try them.What other spurs are available? Think I'm on the 39mm diff, does that matter?
I think i put a 26t on my light talion and had a little room left. 27 may fit.Honestly, I wish I could get that same mount without the fans for cheaper lol. They don't even list the fan rpms or anything, I just instantly replaced them with some 16k rpm aluminum framed ones. With those castle combos I always feel weird because I feel like I'm running a big pinion but my temps are always 90-100f whenever I check. Even my felony for example is running a 26/46 with motor temp cutoff set to 160f and I'm sure I don't even come close to that. I've been thinking of going with a 27 tooth in the Talion. Do you happen to know what the biggest pinion that will fit with the stock mount and 46t spur?
