Do you think with those weights in the differentials the car will put the power to the ground better?i like it the way that it is now it’s just that I would like for the wheels to put more power down to the groundthat should work just fine, but in reality, only you can determine whether or not it feels right for you
Do you think with those weights in the differentials the car will put the power to the ground better?i like it the way that it is now it’s just that I would like for the wheels to put more power down to the ground.
The good ol radiolinkMoving quick. What radio do you have?
Do you have a link to the wheels that you are using?Moving quick. What radio do you have?
I heard that’s a great radio you can turn up different things like power ect…The good ol radiolink
I want to keep the speed it has but rip a little harderthat should work just fine, but in reality, only you can determine whether or not it feels right for you
https://methodrc.net/collections/tires/products/terraform-all-terrain-belted-1-7-1-8th-
Thanks going to try a set out I currently have the stock belted wheels that comes on the talionhttps://methodrc.net/collections/ti...ires-on-switch-17mm-hex-wheels-2pcs-not-glued
Really great tires on the talion and mojave. I haven't tried jumping with them. I have jumped with the MT version on my kraton though.
short-course-tires-on-switch-17mm-hex-wheels-2pcs-not-glued
Thanks I am going to give them a try. I currently have the stock belted wheels that come on the talion exbhttps://methodrc.net/collections/ti...ires-on-switch-17mm-hex-wheels-2pcs-not-glued
My stock titles wore out fast. Those methodrc tires last a lot longer on road for sure.Thanks I am going to give them a try. I currently have the stock belted wheels that come on the talion exb
are the method rc sc tires the same hight as the stock tires that comes on the talion exb?500k in the center for me and the wheels stay down. It also depends on what tires you're using.
Thats with 500k in the center but using MethodRC SC tires.
IIRC they're like 10mm smaller, so a small difference.are the method rc sc tires the same hight as the stock tires that comes on the talion exb?
