The answers you get are going to be somewhat subjective, but the general consensus is open diffs are more easily fine tuned with a wide range of oil weights and there is more experience with open diffs.what differentials is better exb LSD diffs or open diffs for a talion?
I run mine open just couldn't get them to work right with LSD diffswhat differentials is better exb LSD diffs or open diffs for a talion?
any issues? what issues did you have with the LSD diff?I run mine open just couldn't get them to work right with LSD diffs
it was for me too over complicated. just couldn't get them to work right either kept taking them apart and adjusting them but they seemed too tight to me the talion exb ran like it was on ice out of the box, I ended up getting the shim kit for 3 diffs and it runs fine nowany issues? what issues did you have with the LSD diff?
yeah the talion does run like it is on ice that is one of the reason why I want to change out the diffs to open diffs and change the stock fluid to a heavier diff fluid I want the wheels to dig a little harder in grass/dirtit was for me too over complicated. just couldn't get them to work right either kept taking them apart and adjusting them but they seemed too tight to me the talion exb ran like it was on ice out of the box, I ended up getting the shim kit for 3 diffs and it runs fine now
so did I was a total nightmareI hated the LSD in mine, using the shim kit i now run it open.
