- Felony
- Fireteam
- Infraction
- Limitless
- Kraton 8S
- Kraton EXB
- Kraton 4s
- Mojave EXB
- Notorious
- Outcast 8s
- Outcast EXB
- Talion EXB
- Typhon 3s
- Typhon 6s
- Typhon TLR
sooooo it's safe to order ARA330608 to replace my shock rod end now? Wifey just busted one and I found this thread.Let’s make things even more confusing:
While searching for shock rod ends for my Kraton EXB I found this thread.
Read it all, was irritated that Arrma messed this up but still thought I’d take a chance and order ARA330608 and AR330338 along with the steel shock balls AR330206 and some other parts like the tekno rod ends and balls.
To my surprise ARA330608 had the right rod ends and spring retainers, just like the factory ones on my KEXB
But interestingly AR330338 was missing the second sets of spring retainers .
Also, 330608 being the same as stock means the steel shock balls just don’t fit at all on the EXB Shocks…too small for the upper mount and too large for the shock rod end which uses a 5.9mm ball.
Good job Arrma
