Hi,
First time out today with this car and everything was generally fine but did notice that the wheels seem to wobble around quite a bit. This is more obvious at lower speeds. Is that normal? Is there something I can tighten to eliminate it?
Also, if I reverse it’s all over the place, doesn’t go in a straight line, off to one side and the front wheels vibrate and wobble significantly. Is that normal? Doesn’t seem to have any setting to adjust the trim for reverse.
Thanks.
Thanks.
