I was talking about the part that attaches to the arm. Thanks wasn’t sure about itAre you talking about the grub screws on the bulkhead cover or the grub screws on the piece attached to the arms? The former should be snugged but still allow the sway bar to rotate. The latter should not allow the sway bar to slide in and out but if you tighten it too much you will crack the plastic so go gently on it.
Can you look at the rear sway bar for reference?
