- Kraton 8S
- Mojave
- Notorious
- Senton 6s
- Talion
Selling my Talion 6S V4 , its used and about a year and a half old , and while it has its age showing with the typical scuffs / scratches , it's nothing more than you would do to it . The worst looking is the bottom of the chasiss . Mechanically / electronically its fine and runs great !!!
The truck has the important upgrades to make it strong and reliable :
1) Tactic radio
2) Aluminum chassis braces
3) RPM arms all around
4) M2C acherman bar ( kept bending the orig )
5) Aluminum heat sink / fan on motor
6) Fr and Rr Tbone basher bumpers
Recent new ESC fan , and just went thru the shocks and diffs , stock weight shock oil 2000cst , diffs are 20k front / 300k center / 20k rear . It currently has a 16t pinion on it .
The bearings are all still original so it probably could use bearings although I have been driving it like this , you can hear some squeeking when you turn and are rolling .
Has been my go to / dependable basher that 99% of the time comes home unbroken . Going over the truck , the only issues are that early on I tried to get out the grub screw for the rear diff / driveshaft outdrive and stripped the grub screw ( been like that for long time , still no need to remove ) , and one of the wing mount screws snapped at the diff housing , but still hold the wing fine .
Will start out at $400 for it , if no takers will consider to lower price , local pickup in central Ct , or buyer to pay actual shipping .
1) Tactic radio
