Yeah, the Outcast guards. I ordered today and just thought about the motor differences. Good to hear there isn't an issue!If you are speaking about the outcast side gaurd then yes but the smallest bit
I installed the Outcast side guards on my v3 Kraton (stock motor) earlier this year. No trimming necessary.If its going on a kraton you will have to do some trimming at the ends because it is a swb chassis and the kraton is lwb it will work well with cutting it to fit.
Please show pictures of how you didn’t trim outcast side guards that are supposed to go on a swb fitted to your lwb without cutting. It is impossible.I installed the Outcast side guards on my v3 Kraton (stock motor) earlier this year. No trimming necessary.
Well then, my bad... the m2c chassis must be different there. ? well I’ll be damned. Sorry guys ?? the oem chassis the side guards bolt up fine.. I had to dig a stock chassis out of the bins! I’ve been modding them for the m2c chassis so many times it was like yea that needs trimmed... well. No It doesn’t... ??This is my stock v4 kraton LWB chassis(anodizing stripped clean) I didn't have to trim anything on the Noto/OC side guards. It bolted right in place.
I do have an m2c chassis with 1717 mnotor. Good to know I'll be good!I thought maybe yours was an M2C... For a split second I said your chassis is awfully thick compared to mine. But I thought it was your camera playing tricks, or my eyes. I am getting tired.
I'm out . Need sleep.
Alsof like what you die with the steering plate and the red ? look Nice ?@MrTJox1 Needs to put the swb high side guards on his LWB Kraton with a CC1717. The the 1717 is 85.1mm long.(47.6 wide) The stock motor is 74mm. It has to be trimmed for the 1717 at the rear slightly for length and the side should fit without trimming if without a HS.
Below is a picture of my Kraton with the Noto/OC side guards and with a stocker 2050kv.
I'm assuming it's this - "Tall Side Guards Outcast Z-AR320352" ?
Is there a similar one for the Kraton EXB that goes all the way to the rear section?
The down side is that I am in Canada and US customs and USPS are screwing international shipping so it will be a few weeks likely before I can get the parts. But it's a great pile of stuff for $25. Shipping on top of that of course, but still - great deals.
Are there any kit-breakers operating in the UK? I'm in Canada so I'd rather find one in-country but it's unlikely. The UK is big enough that you may have such a thing.Biggest downside for me is that I am based in the UK!
