Reubydoobe
Reuby Doobe
- Mojave
- Notorious
- Outcast 6s
- Talion
- Typhon 6s
In the process of doing this myself. Building the MT410 opened my eyes to some better designs no doubt. Hoping to adapt 4mm shafts too if they'll fit stock Arrma shocks.Do yourself a favor and purchase these Tekno Locking Shock Rod Ends and Spring Perches. They're far superior to the Arrma parts, and will fit on stock shocks with no modifications.
Wish I had of seen this last week when I ordered Shims from a (sorry the one ) Tekno dealer in Aus.Does the .8mm make a difference in the shafts ?Do yourself a favor and purchase these Tekno Locking Shock Rod Ends and Spring Perches. They're far superior to the Arrma parts, and will fit on stock shocks with no modifications.
Do they change the length at all?Do yourself a favor and purchase these Tekno Locking Shock Rod Ends and Spring Perches. They're far superior to the Arrma parts, and will fit on stock shocks with no modifications.
The 4mm shafts do fit, but you have to drill the shock body out larger and the plastic spacers between the o-rings will no longer fit. Those have to be drilled/adapted, also.In the process of doing this myself. Building the MT410 opened my eyes to some better designs no doubt. Hoping to adapt 4mm shafts too if they'll fit stock Arrma shocks.
I noticed no difference in handling.Wish I had of seen this last week when I ordered Shims from a (sorry the one ) Tekno dealer in Aus.Does the .8mm make a difference in the shafts ?
I didn't measure them, but I'd be confident in saying no. I changed all of mine and the truck handles the same. If the length does change, it's so subtle I don't think you'd see a difference anyway.Do they change the length at all?
Thanks so much guys for your feedback on this. I could've checked fitment stuff more with Arrma vs Tekno when doing my MT build, but have been busy lately and just wanted to get the kit built...Lol. Definitely upgrading my shafts and shock rod ends SOON. Figured I'd need to mod them a bit, but definitely worth doing. My Arrma fleet needs some tool time, hard BIG air bashing has caught up. Any suggestions on ESC upgrade??? 3 of my 4 BLX185 seem to be crapping out with broken set switches, 2 have no throttle after yesterdays bash...Lol. Thinking Hobbywing max 6 or 8???The 4mm shafts do fit, but you have to drill the shock body out larger and the plastic spacers between the o-rings will no longer fit. Those have to be drilled/adapted, also.
Haven't yet needed to replace mine, but when I do I'll be looking at Castle systems. Both of my kids are running Castle and I'm more than impressed with them. It'll likely be the Mamba Monster 2 for me.
May look at Castle combo, already been shopping around...Lol. Thanks bud.Haven't yet needed to replace mine, but when I do I'll be looking at Castle systems. Both of my kids are running Castle and I'm more than impressed with them. It'll likely be the Mamba Monster 2 for me.
I swapped for waterproof Savox sw1210sg and LOVE it. Not cheap, but super quick with plenty of Torque and great centering, very smooth too, no Glitch buster required.As for the Tekno shafts the 122mm fronts are the same as Kraton fronts. The 137 rears are real close. The difference isn't noticeable. There is a picture in the thread about Tekno shock ends. I tried to post for you but phone won't let me. I'm happy with Tekno shocks so far. Those are the measurements though. Someone in one of the other threads ordered 107 for fronts and had to send them back. Good luck... Hey there are threads on this but I just fried my servo. You guys are talking electronics what are you running for servo?
Thanks very glad to hear. That's the exact one I been looking at. Do you run a BEC? It looked like if the Voltage is bumped up to 7.4 the torque is over 300.I swapped for waterproof Savox sw1210sg and LOVE it. Not cheap, but super quick with plenty of Torque and great centering, very smooth too, no Glitch buster required.
I don't run an external BEC, still has plenty of torque without it at 6.0 but who knows maybe I'm missing out...Lol. Will say the servo is a great upgrade in performance and durability. I've stripped out 3 of my 4 original Arrma servos. They gently landed into one of my RC "death piles"...Lol.Thanks very glad to hear. That's the exact one I been looking at. Do you run a BEC? It looked like if the Voltage is bumped up to 7.4 the torque is over 300.
I used my stock ones. Worked fine. Still using them today.Ordered these up and put them on the shocks.... then looked at them.... I'm gonna need bigger balls! Ahem..... What size are the ones I need anyone know?
Stock Arrma should be 6.8mm also.
I just posted that cuz Tekno may be cheaper. I once payed 16$ for 4 Arrma balls!!!Stock Arrma should be 6.8mm also.
