ajdragon
- Raider
Hi
Well the Team Associated SC10 shock absorbers came in yesterday and I got them mounted up. I had to use the stock Arrma springs and shock cups and rod ends. The front shocks ended up being 84mm eye to eye, I may add another down stop later on. Now all I need to do is figure out how to calibrate the shocks. right now I have #2 pistons all around and 40w up front and 50w in the rear. And just so you know the stock Arrma springs are just a little bit short, I do plan on buying so A.E. Spring kits in the near future.
I think they look really good on it.
I also had to make the holes in the shock bushing bigger so they would slide on and off.
The tabs on the shock caps are a little bit short so I had to grind off some aluminum material here. See Arrow.
Is it just me or dose the bottom of the shock look like it is being pushed forward by the a-arm.
