slick2500
Anything will break if you drive it wrong enough.
Community Leader
ArrmaForum Fan
- Location
- Rapid City, SD
- Fireteam
- Kraton 6s
- Kraton EXB
- Outcast 6s
- Senton 3s
- Typhon 3s
Found this on Bookface. Not sure why the link is to some random website from the Netherlands.
https://www.toemen.nl/arrma-tlr-tun...6CTi0SgnOpLwohbYLfwJoCWFR0IbhbQPIQYgU1jIziQTg
Details curtesy of @BashingBrian
ARRMA TLR Tuned TYPHON 1/8 Race Buggy 4WD Roller
Featuring premium parts for durability and handling, the TLR TYPHON 4WD Buggy provides bashers with the perfect platform to get started in racing and tuning. Just add your electronics.
Loaded with high-end parts to improve strength, handling and long-term durability, the 1/8 scale ARRMA TLR Tuned TYPHON 4WD Race Buggy Roller offers bashers the perfect platform to enter the competition and experiment with their chassis for get the best performance. The large number of TLR Tuned parts and the factory finished bodywork with a bold racing color scheme immediately sets this model apart from its Speed Buggy sibling TYPHON 6S BLX 4WD. The TYPHON 6S BLX 4WD Race Buggy Roller from TLR Tuned is the ultimate ARRMA 1/8 scale buggy, ready for use on the racetrack and rugged enough for off-road use.
Durable TLR Tuned aluminum upgrades include
a good start.
Main features
Arrma TLR Tuned Typhon 1/8 Race Buggy 4wd Roller
Part number: C-ARA8306ARRMA TLR Tuned TYPHON 1/8 Race Buggy 4WD Roller
- Chassis plate,
- Steering rack,
- Adjustable upper and lower suspension brackets,
- Shock bodies and front and rear shock towers. All are laser engraved with the TLR Tuned logo.
- The chassis also has strong composite side pods and front and rear reinforcements. The adjustable, oil-filled shocks feature machined tapered pistons and Extreme Bash (EXB) stops.
a good start.
Main features
- Strong composite frame braces front and rear
- Heavy-duty composite chassis side pods
- Rear suspension dirt guards
- Adjustable oil-filled shocks
- Machined tapered shock pistons
- EXB Extreme Bash shock mounts
- Heavy Duty transmission
- Transmission durable steel trees
- Tensioners galvanized
- Servo protection spring X-Hard
- Support easy sliding engine access aluminum black anodized
- Support black aluminum servo
- Race Spec high rear wing support
- Race Spec adjustable rear spoiler • Factory finished Race Spec body colors and decals
- dBoots® Exabyte race compound tires
- Low-drag 1/8 buggy wheels
- 17mm aluminum wheel hex
- 2 year warranty (see support website for details)
- Scale: 1/8
- Length: 515mm
- Width: 312mm
- Height: 189mm
- Weight: 2.86kg
- Wheelbase: 328mm
- Frame: 3mm plate, 7075-T6 aluminum
- Suspension: Independent
- Type of shock absorber: Full oil, coil springs
- Drive: 4 driving wheels
- Differential: 3 speeds
- Wheel type: 1/8 Buggy (17 mm hexagon)
- Wheel diameter: 83 mm (3.27 in)
- Wheel width: 42 mm (1.65 in)
- Tire diameter: 118 mm (4.65 in)
- Spur gear: 50T
- Gear pitch: 1.0MOD - Internal gear ratio: 3.3
- Deployment (tire circumference): 371 mm (14.61 in)
- Body: Painted and adjusted, decals included.
- Ball bearings: Rubber protected ball bearings
- Experience level: Intermediate
- Recommended environment: Off-road
- Assembly is required: Yes
- Approximate assembly time: 1-3 hours
