Hey guys
Looking at the Tekin RX8 esc & T8 gen 3 motor for my K6S. Any one out there have experience or opinions on Tekin. Could use suggestions on motor kv aswell.
I have a rebuilt tekin2050 motor/ rx8 it’s definitely race setup and quiet. Folks look at you like wtf bashing rx8 lol the settings to set up are confusing a lil to many beep, hot wire Would work better. I put mmx 2200 in both 46 spur 16t typhon 6s and eb48.3 stupid fast maybe to fast for bashingHey guys
Thanks man, great info..Most sensored ESC's are not waterproof. Because of the sensor wire ports. IMO. They can be made water resistant up to a point using Dielectric grease sparingly around the sensor ports. (motor and ESC side) It's sometimes included with sensored ESC's. That's one Con with a Sensored setup. So rough bashing in the wet is no good with them. No BLX motor is waterproof IMHO. Water ingress will happen if submerged in water. Any non sensored type motor will work in any Sensored ESC. Sensor parameters just wont be available within the ESC. Same holds true with a Sensored motor being used in a Non sensored ESC. Its works fine. Alternatively you can run a sensored motor with a sensored ESC in NON sensored mode by NOT using the sensor cable between them. Works fine as a non sensored setup. There are options in this regard. Many don't know this.
Edit: I like sensored setups because of the low end torque control it affords. No cogging effect. Bashing doesn't always require that. But I find it very easy to get hooked on sensored setups. There is much more precision in TH control at the low to mid end of the TH curve. There is basically 2 types of sensored setps for most high end sensored ESC's Pure sensored and Hybrid sensored settings. Hybrid setting means that the sensor (hall effect) is used only until the torque curve has peaked and then reverts to NON sensored as full TH is reached. I prefer this for bashing and Speed running. Full sensored setting is generally used at the track to dial in a fast rig for a closed course track. The sensors are used up and down the complete throttle curve, always in control.
I just thought I would share my experiences and what I have learned. There is much here to digest.
