Kraton Tekin products
I just started doing research looking for less heat with out monster fans if possible
What I’m starting to learn is that higher amperage esc and lower motor kv equals less heat.
I may be wrong.😬
Also larger sized motors. My coolest running rc that I have is my Outcast with the Max6 4985 1650kv combo in it.
Idk how well the RX8 would work in the Arrma 6s rigs as I am not sure what the limitations are as far as what motors you can run with it. Most of the guys I see that run them in bashers run them in the Tekno MT410 with the T8 1700kv motor on 4s and the MTR410 is a bit lighter than the 6s Arrmas.
My limited research is they only support up to 4s. They have sensored capabilities which is favored for the racing crowd. (But I could be wrong)
My thoughts as well... probably a question for Tekin. I'm at all not versed in the structure of an ESC and it's workings.
The RX8 G3 can do 6s @1700kv or less.
This is what the specs say…Motor Limit Brushless Mode: 2S - No Limit; 3S - 4000kV; 4S - 3500kV; 5S - 2200kV; 6S - 2200kV😉
Although it seems odd that 5s and 6s are the same. Misprint maybe?🤷
You are correct sir. Amain has it wrong. This is Tekins website….
3S - 4000kV
4S - 3500kV
5S - 2000kV
6S - 1700kV
