martysmith223
it's not alot thicker but its definitely like two factory ones gonna use it anyways cause rich dI have bought some but not fitted them yet, I too would be interested if they add more slop etc..?
Great guy at Tek_jo, might drop him a msg.
Personally I'd soak it in some diff oil before fitting in order to help it seal nicely when fitting it all back together.it's not alot thicker but its definitely like two factory ones gonna use it anyways cause rich d
always do lol but thanks guys im just over thinking lol just doing anything I can do to the diffs to make them betterPersonally I'd soak it in some diff oil before fitting in order to help it seal nicely when fitting it all back together.
For me in the US, I actually found the Tek_jo's to be slightly more expensive than the Arrma's because of the shipping costs involved. I think it's definitely worth the slight difference in price though. The Tek_jo's are just a little thicker, and hold up better. As other's have mentioned on here, soaking them in lighter weight diff oil helps{I soak mine overnight}.. Especially if you're running a higher powered setup than factory. The stock Aarma gaskets tore on me, no tears when running the Tek_jo's.Are they cheaper than the ones from Arrma?
You can contact him trought ebay with tekjoAny one have this guys email? Googled it. Nothing came up.
