Outcast Tekno mt410 vs Outcast diffs
Hye
Los Angles
Tekno's out drive shafts are the same width all the way threw. Pins are thicker and planetary gears are beefier.
Do the gears fit in the arrma diff ?
Or does the tekno diff fit the car ??
No. It's the first thing I tried to do. Maybe a team Durango one might fit since everything else is interchangeable.
MT410 on the way! Probably gonna run stock kraton tires on it. They work well for me.
A picture is worth a thousand words. I wish those gears were compatible with Arrma differentials. Although when properly shimmed I've found the arrma diffs to be pretty tough.....no failures yet.
Yes, since I did the shims and pin upgrade my arrma diffs are doing well too.
Thanks for the tip on upgrading the pins!! Pulled my outcast down to service and rear diff pin was in 2 pieces. I didnt even know it, fluke i caught it when i did lol. I ended up cutting a little screw driver up but will prefer a stainless frill bit. Cheers!
Good catch. The gear would have certainly broke next.
Im still waiting on shims to try in mine...
Got some associated ones coming. No one seems to know the sizes so im hoping the fit ?
http://www3.towerhobbies.com/cgi-bi...We52gEJo3BUoPZR_JKTGrFgstPqkMmOcCyBoCz8fw_wcB
http://www.activepowersports.com/te...71eBcN9G6G9BA0DLFcQR8PeH-UL8aEaQs8hoCleTw_wcB
These are the ones I've seen online.
I have personally used the mugan ones from tower and they work great. The size is in tech notes. 5x18mm (.2 thick)
Activepowersports.com can say they have something in stock and after you place your order they will send you an apology saying their computer says they have it but nothing is on the shelf. This has happen to me in the past with them so heads up. They will send part but it takes a very long time.
