VapeLifeGuy
After removing the grub screw in the drive shaft normally you can just grab the gear with a needle nose pliers. It's not working! How the heck do I get the Input gear out from the front differential?! Do I need to remove the motor and center dif to push it out? Any advice would be greatly appreciated. Thanks.
