Notorious J
It's gonna break, so might as well send it!
ArrmaForum Fan
Hospitality Award
Rig of the Month Winner
- On a midnight train to nowhere
- Gorgon
- Granite
- Notorious
- Typhon 6s
A short bench trial to see how the O rings would work. The 2.5mm fit nicely between the lugs. The 5mm cause the tire to distort. A slight larger inside diameter for the 5mm might be better suited. Both wheels have two winds of previously added 50lb fishing line which became immediately ineffective once the O rings were installed. Immediate conclusion without any outdoor testing, is that the 2.5mm, glued, would be effective enough to keep ballooning to a required minimum. I will return the 5mm x 90mm and opt for something around 5mm x 95mm for another test.
