Vanning
I've noticed that the pinion, spur, motor mount and center diff get hot. I decided to make up a fan and pipe in outside air right into this pocket between the ESC, motor gears and center diff. It seems to work well. The motor, diff and esc all get some fresh air from outside.
The motors pinion and drive shaft are sapping lots of heat from the inside of the motor, the motor mount is collecting heat off the can. So I'm trying some cooling directed here rather than on just the can. All is well and the fan is small and light. Today I ran hard in grass, I never ran too hot (180) , 5S, 14 tooth, badlands. I maybe hit 150 at the end of my run when the ESC Lipo cutoff hit. The setup is good and some external cool air piped in seems to help.
I used the fan from the stock ESC that came in the Kraton .
