Tex Koder - Table of Contents
Tex Koder
2D , 3D Not a problem. I'll take that Challenge.
Dallas, TX (USA)
  2. Infraction
  3. Kraton 6s
  4. Mojave
  5. Senton 3s
  6. Vendetta
Just wanted a better (easier) way to organize and keep track of my assorted projects.
And, to be able to quickly access them from my Build Thread Link (under my avatar)
I will update this thread as things come along.
Build Projects:
Project : SRX
Project : WildFire S.A.R.
Project X for Mr. Duke
Project : Escorpión Azul
Project : CoppeRRhead
3D Designs:
Custom 3S/4S Receiver Box DELETE - Servo Mount ONLY
Custom EC5 connector EPS - Easy Pull Sleeves
Custom FLAT Receiver Box Lid (Infraction 6S)
Custom 6S chassis Motor Mounting Holes (Flipper) Drilling Jig / Guide
Spool Making Jig for Spooless 3D filaments
Custom 6S Receiver Box ESR - Extensions Spacers Raisers
Custom Metal - Dual 40mm Fan Motor Mount
Spektrum 150A ESC Fan Casing Delete
Custom 3S Center Brace MOUNTS
Custom Front Splitters for Vendetta / Infraction 3S
Custom - Da Beers - DIY Bodies
Custom "SwitchBlade" Front Upper Arms - for LibertyMKiii's Aero Max Project
Custom Side Skirt Mounting Rails (Limitless)
Custom QUAD Cooling Fans & Motor Support Brace
Custom 35mm to 40mm Fan Adapter : Spektrum Firma 150A ESC
DiamondBack <> 4S v2 Chassis Spine Block (CSB) with Integrated Motor Mount Brace
Outcast - Kraton 4S V2 Mudguards ( can use M3x5 or 6mm screws. Confirmed by DLK83 via txt ,Sep.6,2022 )
Kraton - Outcast 4S V2 Motor Supports
Lambo Aventador SVJ JOTA Custom Front Splitter : J.D. Edition*
Lambo Aventador SVJ JOTA Custom Side Mirrors
Custom Felony Front Splitters : Concept Draft
Custom Infraction Front Splitters : Winglets (Widebody)
Custom Carbon Fiber Center Brace [ Double Barrel ]
Custom 6S Motor Supports
Custom 4080 Motor Support
Custom Typhon 6S Front Shock Tower Skid/Protectors
For Sale:
Infraction - Custom Front Splitter : Mach3
Works in progress:
V2 OC4 build using the V1 K4 chassis
Outcast 4S V2 Roof Sliders & Hood Protectors
Kraton 4S V2 Roof Sliders & Hood Protectors
Kraton to Mojave X-tended Custom Wing Mounts
Apps / Programs & 3D Machines (I use directly or have access to):
Inkscape
Trimble SketchUp (Heavily Modded)
GIMP
Autodesk Meshmixer
Adobe Illustrator
Adobe Photoshop
Blender
Hardware
Creality Ender 3 v2 :
Enhanced with Ender Extender 400XL (Heavily Modded)​
Anycubic i3 Mega (Heavily Modded)
Tevo Little Monster Delta (Work in progress)
P3Steel (Work in progress)
HICTOP (Decommissioned)
PolyPrinter
Modix
Markforged
Miscellaneous:
1:1 Scale Mojave - Whoopocalypse Now
Double Drats! Gauntlets has been dropped!!
2024 Ford Dark Horse
Lipo Battery Safety:
Oooooops!!! 💥🔥😂
RC car explodes in family's kitchen in Fresno County
Smoke Detectors...
Safe battery temperature?
Battery storage for 6s lipos?
Do you store lipo’s in your garage?
DIY Ammo Can Lipo Charger
Ammo Cans
Storing lipo
(Big Ammo Cans!)
The Power of a Full Charged 6s brick... Never let your guard down!!!! Or else.....
Special NOTES:
DS3235 35kg Servo just got a PRO upgrade, More Power! -by parcou
Steering Servo - How much torque do we really need? -by Thumper33
Arrma Screws Part Number Decoder (Very Handy) -by Jerold
Kraton 4S v2 - Driveshaft C-clip heat shrink hack by Gedrick
Kraton 4S v2 - Long CVD for Granite with Typhon RPM arms by HZRDOS
3S Vendetta & 6S Chassis Specifications Details by fish
6S Shock Tower Comparisons :: Model & Dimensions by fish
6S Chassis Size Comparisons with PHOTOS :: 6S XLWB & LWB Big Buggies made from Typhon, Kraton, Talion and Mojave Bits 'n Pieces by fish
Traxus XRT motor size specs
Fan Mount for Castle 1717 motor
ESC Rebrand Conversion Guide
Functional parachute
Shocks & Diff cleaner / degreaser - Use Naphtha (which is Coleman camp stove White Gas fuel)
Can I clean differential with gasoline?
Lipo Battery Charge Rates - What is a Safe rate? - by nomis38
Custom Hardware Parts (from other AF Members):
Custom Carbon Fiber Tower to Tower Braces MAKING - by ColosTommy
Custom Carbon Fiber GT Chassis MAKING - by Greengaunja
Carbon Fiber Chassis Braces MAKING -by Greengaunja
Updated Stiffer Titanium Springs
Arrma Limitless, Infraction and Felony Titanium Springs
Titanium 6S Motor Mount Screws
Adding BUSHINGS / BEARINGS to output cups at center diff ( Both sides ) & Housings F & R
DS3235 35kg servo just got a PRO upgrade, more power! -by Parcou
Custom Louvers for Infraction 3S
How many RC bodies do you have on hand in your garage Ajag? (answer = 30-40 units at all times!)
3D ESC Power Switch Cover / It is coming along! -by RCbuzz
Baby Bath Tub Bodies (for Speed Runs) - by King blitz
How To's by other AF Members:
Build and Shim Arrma Metal Diff case (ARA220050) for all 6S models (VIDEO) -by HardcoreRC
CHOPPED OEM aluminum rod - Center brace for Vendetta / Infraction Mega / Infraction 3s by dpderr
How to FIX 4 Blinking GREEN LED ESC issue / NO Throttle Problem
How to easily revive Chewed Wheel Hexes
Arrma Screw Part number Decoder
What Diff Fluids to use
Design Questions:
Sideskirts any good? -by bladefan
3D Questions:
3D Challenges Accpeted:
Need Nascar Truck wing 3D printed
Carbon Fiber Center Brace w/ESC platform - for K-BASH
Hobbywing Max6 ESC Custom Fan Cowl - for dpderr
Castle Mamba Monster 2 ESC Custom Fan Cowl - for slick2500
Magnetic Body Mount System : Infraction - for Fishtank
Custom X-tendo 3S chassis - Double Drats! / Gauntlets throw down - between Me and StephenSchandelmayer
Chassis Chop Extendo Kraton 4s v1/v2
Custom Typhon Body Vents - for NMango (Put on the back burner.)
Bigger 6S Receiver Box
3D Modded Suspension Arm 3S - Almost got a full 4S rear driveshaft into my 3S but failed at the finish line -by chilly81
1:1 EV Racecars:
Roborace
McMurtry Spéirling
Aerodynamic NOTES:
Why do Diffusers have Strakes/Fins?
The Next Step in Splitter Endplates? Infinity Wings Explained
How Do Diffusers/Splitters/Undertrays Work?
How Porpoising was caused by the 2022 F1 Rules
How Do Air Curtains Work?
How did F1's Trick Dual Rate Suspension Work?
The Beginners Guide to Aero Modifications for your Car
What Speed Does Downforce Start Working?
Vendetta handling
>> Automotive Aerodynamics Episode 1: Flow Visualizations of MR2, RX7, Supra, FRS
908 Project base on ARRMA Limitless - up to 250 MPH -by 908_project
Interesting OTHER Members' Projects:
Project Felony C8 Corvette -by TyphonTLR
Custom Springs for Heavy Kratons 6S
The ideal body for Speed Runs - Carbon Fiber Hand Layed Bodies -by LibertyMKiii
Project SCYLLA -by ColosTommy
New project! Custom chassis. "King Carbon" -by StephenSchandelmayer
Project Custom Chassis Super Stretched Dual Motor 6s "Goliath" -by StephenSchandelmayer
3S Dual Motor Plate Mount -by Logan's_Rcs
Kraton Custom Carbon Fiber Body -by Badtouch The Basher
Wide Vendetta build, TpPower, xlx2, full carbon body -by vwturbowolf
Arrma Infraction 3D printed side skirts V3 (updated with XL rock deflector) -by magnetik
Active Aero Wing on Infraction 6S -by Diem Turner
Project Downforce for VTe2 and Limitless -by Lennart
Extendo Kraton 4s v2. With a 6s center diff and a Fireteam body -by StephenSchandelmayer
Up in smoke yup - ESC Burnt -by Velodromed
Real Aero components for Limitless ( F1 Wing Front & Rear + Side Skirts ) -by Konfucius
Felony / Infraction Hood Scoop - Ram Air System -by nomis38
6x6 Which one of you maniacs created this beautiful monstrosity? -by Springfield1980
Infraction 3S Mods - by DRoc
Custom light kit for Infraction -by oops
Custom light controller for Spektrum receiver/ESC -by oops
Requesting Community feedback for making an RC accessory (not sure what to call it atm) / Lighting Controller & Much More -by kenm04
Jolly Green Giant (Modded Traxxas Sledge) -by TaxpayerTroy
Random NOTES:
Body Outline Trace / Lineart by Dandolorion
Spider bot
Recommended RC Tools to have
Plastic Bottom Chassis Cover
Fireteam shock towers on V5 Kraton by Kyoto
Scam / Fishy sites
My Yoda impersonation
PayPal Tax Warning? (Withhold 24% of sales money ,2023) -from Jester194
PayPal terms
LED Strobes for visibility
Online RC Parts:
Carbon Fiber Heavy Duty Wing Mount for Arrma Kraton 6s BLX , eBay $31.49
Basherqueen Carbon Fiber Front Splitter Arrma Infraction 6S BLX COUNTERSUNK , eBay $34.95 + $5.65
ARRMA Limitless / Infraction 6S BLX Carbon Fiber Front Splitter , eBay $29.69
GPM CARBON FIBER FRONT SPLITTER ARA320520 ARRMA INFRACTION BLX 4WD LIMITLESS 6S , eBay $59.99 (from UK)
XTREME RACING ARRMA INFRACTION BLUE G10 FRONT CHIN SPLITTER 6S BLX 1/7 100MPH , eBay $34.99
Carbon Fiber Front Splitter & Rear Winglets - Arrma 1/8 Infraction 3s & Mega , eBay $19.95 + $3.95
(3D Printed) Upgrade Front Splitter & Rear Winglets - Arrma 1/8 Infraction 3s & Mega RC Truck , eBay $11.95 + $2.95
Shock NOTES:
Integy shock set for Arrma 3s blx (Billet Machined Piggyback Shock Set for Arrma 1/10 Granite 4X4 3S BLX C30939)
Arrma Parts Measurements:
Outcast 8S Rollcage / Rollbar Dimensions
Vinyl Decals:
Forum members got some Cool Branding
Aero Max Logo Decal v0.8
Spektrum ESC Burning Decal ORIGNAL Concept
XLX2 ESC Flaming Decal ORIGINAL Concept
Wicked Chopped Infractions 3S & 6S:
Infraction Photo shoot!
8s Infraction with a lot of 3d work.
Arrma infraction drag truck
Infraction mega speed build (PB 76mph)
AF members WAITING for Custom Kits:
Rizspeedrun - Vendetta Aero Kit (Nov. 12, 2022)
Rizspeedrun - Custom Center Brace for Vendetta (Nov. 12, 2022)
3S LimitLESS
3S LimitLESS NOSE kit
Sideskirts Any Good? by bladefan - 3S Infraction Side Aero Venturi Pods
AF Member Orders :
Dan B. - Custom 6S Chassis Motor Mount Holes Jigs (SHIPPED)
LongBeachRaider - 4S v2 Mudguards & Motor Support (SHIPPED)
Moirae - 6S Receiver Box Extensions ESRs (SHIPPED)
Dan B. - 6S Receiver Box Extensions ESRs (SHIPPED)
Joshludden - 6S Receiver Box Extensions ESRs (SHIPPED)
Smilinbri - 6S Receiver Box Extensions ESRs (SHIPPED)
PeighDay - 6S Receiver Box Extensions ESRs (SHIPPED)
@9G - 6S Receiver Box Extensions ESRs (SHIPPED)
Joshludden - Lambo JOTA front splitter w/Winglets-rearward canted (SHIPPED) [RECEIVED] , [MOUNTED]
BgSkyRC - 4S Mudguards & Motor Support (SHIPPED)
dk3000 - 150A ESC Case Delete Raisers (SHIPPED)
StephenSchandelmayer - DaBOA : Custom Extra-Xtended Double Barrel Center Brace (SHIPPED)
huckfin - Terminator Skulls + Bonuses ; (SHIPPED)
lipo-joe - Outcast 4S v2 Motor Support ; (SHIPPED)
Velodromed - Spektrum ESC Burning Decal LINK (SHIPPED)
Shifty Wanker - 4S v2 Kraton Mudguards (1 set) , 1 4S Motor Support (PAID 11.9.2022) ; (SHIPPED)
Ron Burgandy - Vinyl Decals : 2006 KTM 50 SX (Design Drafts SENT for approval)
N. Mango - Logo Design (Concept Started)
Real_Name_Hidden - Custom 3D Parts Design : Limitless (Design Concept SENT for approval) ; (SHIPPED)
Real_Name_Hidden - 4 sets of SkyRC GNSS protective case (SHIPPED)
paul_c - 1 set of 35mm-40mm Fan Adaptors (SHIPPED)
ArrmaRCfanboy4Life - 1 pair of Lambo Sde Mirrors (awaiting order)
WoodiE
Kind of good admin
Community Leader
Lexington, KY
  2. Mojave EXB
@Tex Koder you can also use the Bookmark function built into the forum:
Doom!
Team Dust Devil
Hospitality Award
Central California
  1. Mojave
  2. Typhon 6s
As @WoodiE pointed out, bookmarks are a great way to save all the cool tips you find on the forum, without having to go back and search. Sucks when you know you saw something then can't find it again. Bookmarks are your friend. (y)
Macster1215
Missouri
  1. Felony
Build Projects:
Project : SRX
3D Designs:
For Sale:
Works in progress:
Inkscape
GIMP
Autodesk Meshmixer
Adobe Illustrator
Adobe Photoshop
Blender
Hardware
PolyPrinter
Modix
Markforged
Miscellaneous:
Oooooops!!! 💥🔥😂
Smoke Detectors...
Ammo Cans
Storing lipo
(Big Ammo Cans!)
Special NOTES:
Design Questions:
3D Questions:
1:1 EV Racecars:
Roborace
McMurtry Spéirling
Aerodynamic NOTES:
Vendetta handling
Random NOTES:
Spider bot
Scam / Fishy sites
PayPal terms
Online RC Parts:
Shock NOTES:
Vinyl Decals:
3S LimitLESS
AF Member Orders :
Did you finish the Nascar truck body wing?
