Doing a Kraton build, just on a Talion chassis, reason i believe this will make it a more balanced ride. So we start this build with the M2c talion chassis, a M2c Motor mount, and a rocket 1650kv motor running a 20t pinion. Max 6 esc. Will also have a power HD S25 servo. Hubs have the M2c locking hub nuts and also running full rubber sealed bearings throughout.
Rear diff has 10k oil in and also added the GKA end stop, awaiting more parts to arrive. But will be adding a M3 ackerman plate to the steering, and also added unpopable ball ends. Will update once more parts arrive ?
Ok abit more progress tonight, laid everything out, nothing is stuck down, did the battery tray mode, and then topped it off with the scrouched parts Carbon fibre Battery tray, added the M3 Ackerman and laid out the scrouched parts driveshafts ?
