I suck at naming.
Anyways this is the journey of taking my Typhon mega 4x4 from mega to what ever it ends up as in the end.
The planned wish list is the same as any other but there are a few extras that I plan on playing around with such as a Custom transmitter and receiver with telemetry.
I've been holding off on making this thread until I actually had to replace parts. And the spur gear was the 1st to fail and get an upgrade.
I went with the Arrma 57t CNC steel spur gear and an RRP 11t pinion gear to keep the gear ratio as close as possible. (stock = 5.353:1, new 5.182:1)
I had previously been debating between the HD spur gear and the steel one because of a comment about preferring the spur gear to get chewed up vs a pinion gear. After getting the new gears I realized that chewing up the pinion might actually be the better way to go because:
Pinion costs as much as a new spur
Pinion gears aren't limited to a specific brand, and since arrma has parts issues, I'd rather have to swap a pinion that I can get from anywhere rather than wait for an arrma spur gear.
I'll be swapping out the pinion gears anyway for different battery and speed conditions.
Before changing out the gears I had failed to check and see that the shaft adapter would need to be changed out when going from the mega spur and slipper to the blx spur and slipper. Thankfully the shaft adapter is aluminum and I just ground and cut off the extra length shown sitting where the battery normally would in the image above.
The next upgrade will most likely need to be the motor and ESC as now when I run the Typhon, the motor smells like burnt enamel motor wire but I don't see any over-heated windings yet. The plan for the motor ESC upgrade will be a hobbywing Max 10 SCT with a Hobbywing 4267 2600KV then play with pinion gear size.
