Mojave The overrated RC. The arrma mojave EXB/RTR
Canada ?? Montreal
  2. Kraton 4s
  3. Mojave
i bought my first arrma mojave in december the day of my birthday. It was fun on snow and i didnt broke anything really even in the -20 degrees weather. But now we are spring/summer and its just causing me problems and more problems. First the body posts. A know issue im at almost my third pair now. The front bumper spring no matter what you do it breaks if it doesn't break on the plastic spring circles itself it will rip where the screw is mounted on the shock tower. And taking those #(#&@)$*#*@ without taking the whole front end is a complete pain. Body rear cracks i found a fix for it so thats not a problem to me. The rear diff housing now i broke one in a nose dive. Had to come back home limping. Bought the shock tower supporT from m2c first pack out. Bent the rear right arm pin bended the steel retainer and took the gearbox with it. And again front bumper gone. ARm too Gone.
my option are these get
-hot racing pin retainers reinforcement
-hot racing gearbox
-go with another stock gearbox
TheCyborgSlayer
Lake Charles, La
  1. Kraton EXB
  2. Typhon 6s
My initial thoughts after the first few sentences was, it was driven in snow, didn’t get it cleaned well enough, and now you have water problems.
As I read, everything that’s breaking sounds more user error. With the exception of the springs, which I would say check that your droop is set up properly. The bending of pins and breaking of bumpers is going to be all on you my friend.
Canada ?? Montreal
  2. Kraton 4s
  3. Mojave
Im picky i took my whole truck Apart cleaned the bearings regreased bought ceramic hybrid bearings for my motor when my truck makes a funny noise i find the noise and i fix it
My trucks are always are their best in terms of health
I went out in snow like 3-5 times in 3 months because its a pain. And i don't shower my trucks like a lot of people do. And i don't go trougth mud Either
The issue if the car likes to nose dive with not warnings and once it does i can go full throttle and nothing happens i become a passenger at that point. The parachute effect also an issue but a bit less because i cuted some vents above the front tires
I had one tire almost strip on me but i fixed it. That also can become a potential issue but i use threadlock and check them periodically during my runs
I boiled the arms also. But i truly think wd40 does benificial stuff. I boiled my kraton exb arms then used wd40 a few times on them and now i can twist them pretty far like a noodle. I once landed on the right rear bended the shock shaft slighly. Still using it because doesn't bind the shock. The new arms are like a rock unbendable by hand. I didn't do that to my mojave unfortunately only boiled them
Canada ?? Montreal
  2. Kraton 4s
  3. Mojave
It's not a Kraton. Body is not made for jumps and yes it will nosedive if you do. Those tiny tires won't help you to get it straight.
Better get a street car to just stay in the ground
I nose dived so hard that the rear right arm pin decided to poop itself my truck was running in crab mode . Nose landed and the rear gearbox exploded. I need a wizard to explain me The physics. My jumps arent so high also. Im just jumping over a short hill
jkflow
TB RC Bashers
ArrmaForum Fan
Tampa, FL 🇺🇸
  1. Infraction
  3. Talion
Some of the physics boggle my mind as well.
Get an Infraction, they don't like jumps either but never had a gear box explode and yes that thing went airborne for 30ft minimum but not on purpose.
There is no controlling that thing in the air either :eek:
skidmarkus
  1. Mojave
The body posts... cut a pool noodle and stick the foam in between the body post loops.. as for the rest of it, you either got a lemon, or you beat the absolute poop out of that thing. Mojave is super popular in my group of friends. 4 of us own one now and one of us has an exb. They have all been the most durable rigs any of us have ever run. hands down. The only thing ive ever broke was a read hinge pin and that was 100% my fault. Got into a drift wide open and smacked the rear right wheel on a mailbox post. Didnt even break the arm, just bent the pin. I jump my truck 40+ feet and lawn dart it. it just takes the abuse.
I do feel for you, because there is nothing worse than being excited for a rig and having it fall apart, i just cant for the life of me see how all this stuff is breaking on you without some extreme talbot style abuse.
The_Otherside
Appleton, WI
Just here to say it's underrated. My favorite Arrma. Owned an Outcast, 2 Infractions, Tallion, Notorious, Mojave and an EXB Mojave.
Skate park bashing, trail bashing and hill climbing. The Mojave is hands down my favorite.
Hope you find better luck!
Canada ?? Montreal
  2. Kraton 4s
  3. Mojave
The roads here Are $)&(@*2*$*@
I have foam blocks under i keep fixing them with fishing line.
6A4A648B-1CB4-4B3B-9089-EC10532C9663.jpeg 36B10739-32B7-4BBF-B6D2-802DBD8332A1.jpeg
Cheez
ArrmaForum Fan
Solutions
So. Cal.
  1. Kraton EXB
  2. Mojave EXB
  3. Nero
  4. Senton 3s
I’m not sure you are in a position to claim something as overrated. 🤔 you sir are a Minority. WHERE IS THE SNOW?
If you choose to bash in an inappropriate environment then the responsibility lies on you to make necessary modifications.😎
Jon NC RC
Keep it fun......SEND IT
ArrmaForum Fan
In the stix…NC Mtns
  1. Mojave
  2. Senton 3s
I also have had good experiences with mine....
I’m loving my Mojave EXB.......no major damage yet, minor stuff. I haven’t nose dived it yet.....😆
I have....
-hot racing gearbox
Sorry this is happening....more power to ya when it comes to running in the cold... things made of plastic don’t fare well when the temps go down....
I hope the future holds better experiences for you....for whatever reason my V2 has taken a lot of tumbles and some good old fashioned beatings with a few times when I cringEd because it slammed into trees and such.....with no real breakage yet.....
hope the same for you
Jon NC RC
ArrmaForum Fan
In the stix…NC Mtns
  1. Mojave
  2. Senton 3s
I am not able to compare with other rigs of the same brand due to the fact that I only own the Mojave and the Senton....
BUT
Considering the Mojave weighs 12 lb more or less with a battery and can go 50 maybe 60mph depending on how it's set up.....
KUDOS to Arrma to produce a rig that can take the abuse that it gets and holds together as well as it does
Cheez
ArrmaForum Fan
Solutions
So. Cal.
  1. Kraton EXB
  2. Mojave EXB
  3. Nero
  4. Senton 3s
BUT
Yep , what he ☝️Said.
Car Crash GIF by memecandy
Canada ?? Montreal
  2. Kraton 4s
  3. Mojave
I bashed on snow even then it liked to nose dive. I lost almost the whole bumper sticker
I have....
Ironicly i didnt break anything in the cold. Only started falling apart in the heat
only a rear body mount gave out but fixed it and exploded when the heat was rising and snow was gone. Same for the front bumper
I want to run it but i cant get rear arms anywhere. I changed the shock oil and pistons yesterday. I made them correctly this time. I think i wasnt threading the bottom hard enough and cossing premature air bubbles over time
Exploding the rear gearbox in a nose landing
GIF by Achievement Hunter
Its all good and fun. But when i have wire and zipties holding my truck togueter. Im looking like stempede. Next time i will use chains🤣
Jon NC RC
ArrmaForum Fan
In the stix…NC Mtns
  1. Mojave
  2. Senton 3s
So..... in your case maybe the Mojave is your snowmobile RC...?????? That is truly strange...
Steve38
Bash IT Real Good!
ArrmaForum Fan
Cleveland TN
  1. BigRock 4x4
  2. Granite
It's all experience man. Im no mojave owner or user. But I run a big rock 3s blx. Love it and hate it. First had a granite with so many probs lhs guys said trade it in. I did got a big rock. Got a little questionable pieces of advice and 3 servos 2 savers 2 diff horns. Motor mount spur gear pivot balls in 1 bash alone. And im hooked for life. Just put back together and gonna run her tom.
