- Location
- In the stix…NC Mtns
- Kraton 8S
- Kraton EXB
- Mojave
- Senton 3s
Yep, you learn as you goIt's all experience man. Im no mojave owner or user. But I run a big rock 3s blx. Love it and hate it. First had a granite with so many probs lhs guys said trade it in. I did got a big rock. Got a little questionable pieces of advice and 3 servos 2 savers 2 diff horns. Motor mount spur gear pivot balls in 1 bash alone. And im hooked for life. Just put back together and gonna run her tom.
I have not done anything like Kevin Talbot has done, but I have sent mine over some steep embankments at speed and then turned it around and went up the steepenbankments as a form of a long steep ramp. Yes mine is nose heavy but if you can get used to throttle control when it's in the air you do have some control over it. Like I said above, the 12 lb object going 50 miles an hour without breaking every thing that is constructed of shows at least decent engineering and quality of buildNot sure how you bash it, but IMO the Mojave is made for offroading with only small jumps due to going fast over little bumps; not for trying to hit ramps etc.
Can't speak for others, but mine is also nose heavy.
