parcou
Hospitality Award
Rig of the Month Winner
- Memphis, TN
- BigRock
- Felony
- Fireteam
- Granite
- Infraction
- Kraton EXB
- Talion EXB
- Typhon TLR
- Vorteks
No disadvantage to the light it's led and takes little power.I just picked up a DB Pro this week and after 6 packs - so far so good!
I was VERY disappointed in the large turning radius so I looked up online and saw how to adjust the DX2E endpoints. However - it still required a little grinding away a little of the steering servo mounting flange in order to get the additional travel required from the linkage. Now it turns nice & tight.
I wouldn't mind getting a bit more run time off the 2S battery, which begs the question; Is there any run time advantage in disconnecting the light bar?
I'm always running in daylight and the light bar is cool at first look but I could do without it if it gained me any run time.
Your turn radius is not something commonly posted I have seen mentioned. I can turn far left and right but I have adjusted my endpoints so I don't max the servo still have plenty or turn. I can make sharp turns. I run on 3S also so honestly I drift it so on dirt my turns are powered by drift to spin in the opposite direction 3S is right balance for this Losi. Regardless, you still should not be locked to wide radius turns. Is this the stock servo?
