Is there any other bulkhead options other than the Vitavon? I don't want to make them aluminum because it is heavy and wont do me any good on the track. As far as the diff goes what other options do you have? Is the lasernut blowing up diffs on 4s?
I have already gotten that for my center diff as one of the stock spider gears decided it was time to lose some teeth. I'll most likely hold off on the 4s conversion for now till I get a better idea weather this car could take it or not, will also browse through some lasernut forums and see what they think.I agree and it is expensive. What I have read and seen are the inner diff parts are breaking down due to the softer metal like the crown gears that turn the spider gears. Lasernut really bad so the DB Pro has not been to that level I only had the rear diff crown gears go bad. My thought or concern and I don't have the experience to know if you go 4S will those gear that comes stock handle that. There is the Ten-T stuff not sure if it will work or any better...
https://www.amainhobbies.com/losi-differential-gear-set-w-hardware-tent-losb3569/p-qqqxtzqabbzxactz
Added a simple mod some did to the Big Rock and Granite by adding an oring on the motor piston. Just added something to help or stop dirt from getting to the bearings for bit longer life. The cover is good and needed but I did have dirt still getting in that hole before adding the oring. With the Big Rock some like me did also cut a hole in the chassis so the dirt can escape which I cannot do on the Losi.
Needed two orings to cover the gap and its not pressing or creating any drag on the pinion
View attachment 154365View attachment 154366
Curious as to why you didn't add the washer where the pinion gear meets the o-ring?Added a simple mod some did to the Big Rock and Granite by adding an oring on the motor piston. Just added something to help or stop dirt from getting to the bearings for bit longer life. The cover is good and needed but I did have dirt still getting in that hole before adding the oring. With the Big Rock some like me did also cut a hole in the chassis so the dirt can escape which I cannot do on the Losi.
Good call out.Curious as to why you didn't add the washer where the pinion gear meets the o-ring?
I just got my DB pro a couple days ago and am going to swap out the bearings and do this mod like I did to my Typhon and need to do to the rest of my rigs lol But in that original thread the guy used a washer I'm guessing so you don't have something metal other than the shaft constantly rubbing against the O-ring?
That does suck that they don't make another brand of metal bulkhead BUT they all seem to be the same price. I know for the 6s arrma line the Vitavon is around $96 and if you go with HR it comes out to close to $105 with all the parts needed to make it fully metal lol
Oh and you guys are awesome for all the recommendations and tips! I just finished reading through the whole thread (took me a couple weeks) hah
For something like that you would likely need a spacer it is an awfully large gap.Good call out.
I had no washers large enough to get over the pinion shaft, or too large like car size large. My fault I really, really need to order a washer set of different sizes keep putting it off. I will circle back and do this.
That's a good idea putting a lock nut under the screw, makes it harder for it to back out.Hey Fam just wanted to give my impressions if anyone wanted to try the belted Proline Badland MX28 HP 2.8" on the Losi DB
Live here in Memphis, hot evening today @ 7p
Yes, these belted tires are heavier than stock but not heavy like weights....as for performance at my level of bashing I did not see anything in weight that slowed it down compared to all my prior tire runs...still 3S fast on the 15T pinion. I ran it in an area with dirt, little grass, rocks, and a little jump across the concrete between the street and dirt.
- 91deg, feel like 95deg
- Ran two battery packs back to back no rest but to change battery, 1st 3S 5500mah, 2nd 5000mah
- Only cut off was LVC, no thermal shutdown ever
- 2 good aftermarket fans on ESC and motor
-- The tires being MX hooked up good to be expected...no ballooning of course...the win
-- In the loose areas, I can turn a 180deg and no flipping it bits and drifts and turn perfectly for their size...no change there
-- In areas like grass or street, these tires will bit and you can flip in a turn so it will tip up one side...not my main running areas
-- Previously, I could get a little slide or drift in those areas on the smaller tires...no loss for me it's a dirty buggy anyway
-- In my opinion, they do not feel or act like truck tires with their more narrow/tall belted setup work well as a SC tire here
-- Added tire on the surface grips so nicely and being MX28 makes it all the better so hook-up is sweet
I am open to other's thoughts on the last one or any of the above...just sharing some my experience if someone was looking at these for their Losi. I am not a jumper with this rig save that for my Big Rock so I rather run the Losi more like a DB, desert buggy, to its strong point.
Tires...feel it still has a nice ratio balance although taller....
Forgot my heat gun to report the tire, battery and motor temps...so this is all I have for the back to back runs for temp only the ESC...sorry....did good on temps this was max on the last battery run and at a stop or rest the temps did move down quickly:
Sorry for the dirty RC pic....better fans do help with temps...especially with the tires IF that is an impact here to a degree of concern for me.....
Fan is lifted on the motor heatsink for more air down-force. Same model fan on the ESC
@KiTris ExtremeRC
I looked at the manual does not say the shock piston sizeDoes anyone know what the stock piston size is? I drilled out my pistons and it did not turn out how I wanted it to. I was looking at these just wanted to compare it to the stock size so if anyone could let me know that would be great
https://www.amainhobbies.com/team-l...k-piston-4-1.6x2-tlr233009/p-quqqqzrqnzzxactz
You need the mm thickness of the piston? Or only the length from end to end or end to threads?Ya the manual doesn't have to much specific detail but next time anyone opens up their shocks please measure.
ok thanks, I wonder if that is the same diameter as the ones I linked above but they (pistons i linked) fit the scte 2.0 which are the same size shocks right?
