Granite Thermal Cutoff Setting
bicketybam
Drives like a barbarian with a bended brain!
New Milford, CT
BigRock 4x4, Granite, Infraction, Kraton 6s, Kraton 4s, Notorious, Talion, Typhon 6s
What temperature do you guys use for thermal cutoff/shutdown? I have mine set at 185. Too high?
Jerry-rigged
Have you seen my LVC?
Texas, Baby!
4x4-Mega, Kraton 6s, Outcast 6s, Typhon 6s
Is this ESC or motor temp?
For motors, 185f is getting into the danger zone. For ESC, I hear closer to 160f-150f is about as high as you want.
kani
Granite
Argh. I was Waiting for p32 mod but I guess there is no sense in doing it.. I don't seem to have spur gear issues but overheating is dull to have.
bicketybam
New Milford, CT
Motor temp. My motor hits 185 after about 10 minutes of use on 3s with the 1410-3800 motor and the 32p gearing .
Jerry-rigged
Texas, Baby!
If you want to do the 32p mod, and avoid heat issues, get a 60t spur instead of the 56t-57t that most people use.
bicketybam
New Milford, CT
You think that would fit? It's pretty tight with a 57t.
Jerry-rigged
Texas, Baby!
If you convert the pitch, the stock 91t 48p is about 60.5t in 32p. Megasty has said he runs the HR 60t yeti spur in a few of his trucks.
91t, 48p = 1.895" dia.
60t, 32p = 1.875"
61t, 32p = 1.906"
