Thicker turnbuckle - Lunsford Racing
Ferreira&5
west boylston, ma
Hey guys, first post here. Got a Granite BLX for my son (and I ;) ), our first real RC car. We already had the stock turnbuckles break 2x. They are crap metal, don't even bend just shear.
SO, I got some Lunsford Racing turnbuckles that are 3.5mm (stock is 3mm) https://www.lunsfordracing.com/mm5/...=LUNS&Product_Code=LNS35072&Category_Code=MET and the matching ball cups, but silly me I didn't get the other end, the ball joint set I think it's called. Problem is I can't get stock ones because they need to accomodate the 3.5mm turnbuckle. Anyone try this before or able to point me toward 3.5mm ball joint/tie rod ends?
Wait I think he means the other end that connects near the front wheel. It's not a cup.
So I fixed this problem. I bought Lunsford Racing turnbuckles but I bought them in 3mm and reused the stock ballcups and the other end also. Stronger than ever!
Thanks, that would work. I ended up grabbing some traxxas 4mm ones. They came with two captured ends, they don't use a ball cup. You can unsrew the ball on arrma grame and srew it tje through screw for the traxxas style.
If these break I might get lunsford 3mm ones. So far so good though, tje traxxas ones are definitely a better metal than the junk stock stuff.
