Iwanitall
- Kraton 6s
- Thread starter
- #21
Yes, 20mill and it broke again. Read responses after I broke it. Like I said I will be changing to 1mill.So did you run it again with the 20 mill and it broke? Im running stock oils and never had an issue but will be upgrading to 500k in the center to help with ballooning. 500-mill is max for the center IMHO, Hell duperbash runs 200 in his stock Kraton and everything else....when he upgrades the motor/gearing THEN he goes to 500. If it works for him...IJS
And did you say you put 20k in the outer diff case? That wont do a lot as it wont stay on the gears...it will run off....try 100% Blood outside the diff.
"And did you say you put 20k in the outer diff case?" Nope. didn't say that. ? I run Lucas Red on the outside.
I can't believe Duperbash doesn't break these more! I guess it's all in the set up, and mines not right yet!
Thank you everyone!!! This forum is awesome!! I'm gonna go change some gears and fluids now.
