I have shimmed all diffs, painted esc fan cover, and a castle fan on motor.
Got ya. You know I’m the same boat as you lol. Really hoping I prefer enough shins and I can figure this out. Never really shimmed diffs beforeYes but i didnt shim center and thats when it did as in the pic
How is the 14t pinion? Are your runtimes shortened now?New servo in. New Dx3 rx/tx coming also exb towers and braces. And a 14t pinion and rpm bumper.
haven't gotten it yet. Waiting on rest of parts before i run it.I started with a 17t but it was too much for it. I could not keep the front down even on punch 2 and the thick diff oils still was fun too lay it on its roof at 40 ??How is the 14t pinion? Are your runtimes shortened now?
Its not much to it. When you take the pin out for the sungear. Use that shim externally on the outdrives if it has any side to side play. Use your mugen to shim satelight/ and sungear (planetary) gearGot ya. You know I’m the same boat as you lol. Really hoping I prefer enough shins and I can figure this out. Never really shimmed diffs before
@SrC you like the metal diffcase?Looks like a combination of a damaged gauged out diff from rocks and debris hitting it and an ultimate demise from overheating. It melted. What happened? any idea?
Use the Arrma Metal optional diff in the center.
You asked about metal diff cases mine are plastic @SrCRpm bumper installed. I left the stock one on for added protection. Next will be the dx3 install and trash the pos stx2
