This worth 25$??
Usually something that cheap isn't good, though I have heard good things about that brand.
Make sure it has all the functions you need, and read a lot of reviews
Yeah I mean I only have the Spektrum non display 10a most charge 1 battery anyway. Atleast I could discharge if needed. Then opens up to buy cheaper batterys. I only have 1 for now but I can grab a cheaper 1 to have also. Cheap is like the going thing atm 😆. Im good with it being atleast equal but with display discharge
I'm sure it will work fine. I use some cheaper chargers that are only like 50w and 80w and they do fine just takes a bit to charge. Also I don't charge over like 3.5A max so would take a while either way but I get longer life out of the packs not charging at a high rate.
Also wouldn't hurt to not rush into that one charger. Keep looking and you might find another low cost charger that will work for you. There is tons out there....especially on BG.
