jkflow
TB RC Bashers
Hospitality Award
You will like it
What do you mean?Don’t forget the servo saver mod if you haven’t already done it
You got it man!Awesome! Please let us know what you think.
If the programmer also allows seeing the current/default settings, I would love to know how it comes programmed from the factory. Like whether the torque & speed are set at 100%, out of the box. Or whether the programmer is required to get the most performance out of it.
I like the basher queen part with the adjustable collar with an alloy servo saver. They work really good. My biggest issue has been figuring out the correct spring tightness.
Thanks! And I realized it might be interesting to see the speed difference (even a video) from the stock servo to the upgraded one. A static test, just sitting on the ground and steering, is easy to check, but maybe doesn't quite tell the whole story.You got it man!
I'm sure you are driving some OCD purist nuts but for bashing this is just fine. Doesn't matter at all other than ascetics.So, this servo is a lot taller than stock. I set it up using some aluminum spacers to level it and I’m wondering if it’s a bad idea to mount it like this. Also, I’m wondering if the slight angle of the link matters or should I even it out? What is the proper way to incorporate a taller servo into my Kraton? Serves me right for not thinking to check the size of the servo
Pardon the newb question as I am new to arrma, and never had to replace a servo on my TRX rigs yet. The Spektrum S652 is 23T and this is 25T, but this will still work fine with the K6 servo linkage?I'd go with the 55kg, allows the use of bigger tires.
I'm using this one:
AGFRC 55KG Digital-Steering-Servo High-Torque Programmable - Full Metal Gear Brushless Servo for 1/8 1/10 RC Models, Control Angle 180° (A86BHM)
You need a servo arm that fits a 25T servo, but the linkage between the arm and the steering bellcranks still works. Hot Racing makes a nice servo linkage system: I have one in my Kraton 6s with a Powerhobby 729MBL servo.Pardon the newb question as I am new to arrma, and never had to replace a servo on my TRX rigs yet. The Spektrum S652 is 23T and this is 25T, but this will still work fine with the K6 servo linkage?
Yeah… ocd I am surely not. Thanks man, much appreciated!I'm sure you are driving some OCD purist nuts but for bashing this is just fine. Doesn't matter at all other than ascetics.
I have a hot racing servo horn (linkage) on the new servo, which is 25T. The original spectrum horn, that goes on the s652 that used to be in the car, is 23T. I don’t mind any questions at all so if you’re still a bit confused, ask again and I will clarify.Pardon the newb question as I am new to arrma, and never had to replace a servo on my TRX rigs yet. The Spektrum S652 is 23T and this is 25T, but this will still work fine with the K6 servo linkage?
Yep, you don’t need it until you upgrade your servo. Arrma servos are the only one that are 23t. The aftermarket servos are 25t.Thanks, now I can say I learned something new today.
I actually already have one of those in my AMZ 'saved for later' under my cart to try out eventually but it sounds like I don't need to do that until I actually upgrade the servo itself.
i think that's wrong. Amazon servos are 25TYeah… ocd I am surely not. Thanks man, much appreciated!
Yep, you don’t need it until you upgrade your servo. Arrma servos are the only one that are. 23T. The aftermarket servos are 25t.
Apologies if I'm mis-interpreting, but I think that's what he's saying? The Arrma ones are 23T, and the aftermarket/Amazon servos are 25T?i think that's wrong. Amazon servos are 25T
Yup.Apologies if I'm mis-interpreting, but I think that's what he's saying? The Arrma ones are 23T, and the aftermarket/Amazon servos are 25T?
