Dman0712
I bought a new v3 Kraton a month or so ago and have upgraded the motor to a Leopard 4092 1480kv. Currently running 20 tooth pinion and stock blx 185 esc. Tried adjusting punch setting already. Tons of power but from a dead stop if i mash the gas there is like a second delay before it get full power. When i give it full throttle it will move a few inches and then full power comes on as the truck flips over. There isnt a problem when i am already moving its only at a dead stop. I also had a random problem yesterday when i went to use the truck. I powered in on and had no throttle input, only steering. I tried playing with throttle trim and all the sudden the truck took of backwards and flipped over. Turned truck off and back on and then it was working correctly but still had the lag from dead stop. Any ideas?
