SaGô
hi, folks! new to the forum, new to RC cars and just received a RTR Typhon V3 from Omnimodels. i read through the manual. initial bench test ok except a few concerns:
- throttle trim on the Tactic TTX300 came out of the box left of center (around 7 o'clock position). most i've seen/read in the manual and other posts say it should be dead center (6 o'clock position), but when i do that, the car starts moving forward. do i leave it alone or calibrate? throttle forward response doesn't appear buggy.
- throttle reverse response is buggy. the ESC is factory set to throttle/brake/reverse on the throttle trigger. at times, the Typhon LAUNCHES IN REVERSE FULL SPEED WITH JUST A SLIGHT PUSH OF THE TRIGGER FROM NEUTRAL WITHOUT ENGAGING REVERSE WITH THE REMOTE. surely this isn't right. trying to replicate it is inconsistent, but usually it occurs when the trigger is neutral and the car is completely stopped. but even then with the car completely stopped, i have been able to successfully perform variable speed reversal. i understand trigger forward twice to engage reverse is normal operation, but the intermittent full speed reverse with minimal trigger movement WITHOUT ENGAGING REVERSE is really concerning. do i have a faulty ESC?
- i noticed front wheel toe alignment out of the box is outwards. it seems too much to me visually (but i'm a noob). i understand this provides more stable turning performance (at the cost of faster tread wear), but is this normally how the RTR Typhon comes from the factory? (and oddly, no turnbuckle tool included?!)
