I had to replace my tie rods on my granite 3s and I did not measure them before I took them apart.How can i get them back to factory settings is there a number for the length they can be set to.
Thanks
Brian
I can not get it to stay straight even at low speed and steering trimmed outLength doesn't matter, it's how you use it.
Just set the wheels to -1 degrees of camber.
The chamber is right the toe is way outI can not get it to stay straight even at low speed and steering trimmed out
After I installed the new tie rod ends set them the best I could the the truck will not track right how do they set it from the factory there has to be some kind of measurement the factory sets the tie rod length when they assemble them that is what I am trying to set them back toSet the steering links to the same length left/right and the wheels straight (no toe out).
As far as it not "staying straight", that could mean about 10 different things, but if you mean it goes straight, then you turn and it won't go straight anymore, that could be tons of things but has nothing to do with your steering links. Most likely crap in your steering rack or servo saver that lost its tension, or a stuck bearing, or servo going out/stripped teeth.
