stuartd
Any advice on whether this is ok or time to get rid?
What are the voltages like?
I would say you are running the battery too low. You want the cells to be about 3.5V minimum when coming out of the car.After I got back home (I often run until the car slows down, but today it stopped under LVC) and put it onto the charger the cells were showing
Upper Row: 3.34, 3.30, 3.31
Lower Row: 3.34, 3.22, 3.34.
I put it onto storage charge 3.80V, the cells have balanced and charged evenly. This took around 50 minutes with the charger set to 5A, although 15 minutes (or more) of that had all 6 cells showing at 3.80V as the charging completed at 0.6A.
It stays cool when charging and internal resistance is the same as it was when new: 1mohm for each cell.
I first noticed it was very slightly puffed a couple of charge cycles ago.
Unfortuantely the BLX185 ESC has a low cutoff voltage which is responsible for this and it cannot be changed.
That's one of the reasons why I bought a MAX8 to replace it. I would use a Lipo alarm in the meantime to avoid this.
