Grumpy Old Man RC
Since I was working on my Kraton and another member just muddied his up,
These SHOULD be safe for use on some RC stuff. They are both supposed to be composite safe and I use them all the time for other things that have a lot of plastic of some grade or another.
I changed out/added diff fluids to my Kraton Tuesday and instead of taking all the gearing out, I just carefully squirted one of these into the case and ran the diff by hand. Repeated until all the black gunk was out of the center diff. Easily cleaned it out.
I didn’t want to take gearing out yet as I have no shims or new bearings so there was no real reason to.
The Hornady cleaner has a dry lubricant in it and I can clean my firearms with it and actually shoot them with no further lube. Some of you may already be aware of these products and some may not but I’ve been using these in my other hobbies for years and it just yesterday hit me. I can see both of these products getting used in my RCs.
Birchwood Casey Gun Scrubber
https://www.amazon.com/Birchwood-Casey-Scrubber-Cleaner-15-Ounce/dp/B07N5GPQ6C?th=1
Hornady One Shot Cleaner & Dry Lube
https://www.amazon.com/dp/B07MVQ8R6...d_r=e88eabb0-4031-11e9-a824-df4daa8f2bd1&th=1
I looked but did not see a general tip/tricks forum.
Moderator(s) move if needed.
