DAWGGONE78
- BigRock 4x4
- Senton 6s
I recently upgraded my son's wheels and tires to the Proline Badlands MX28. Should I have changed the pinion gear?
I don't have the numbers in front of me but I don't think they are much taller or shorter than the stock tires. If that's the case, then no. No need to change gearing. If they are markedly taller then you could gear down. If shorter, gear up. But I think you are fine ???I recently upgraded my son's wheels and tires to the Proline Badlands MX28. Should I have changed the pinion gear?
Ok just wondering cause was looking at changing tires on my Senton and tires I'm interested in are 10mm taller and some say I need to and some say maybe notI don't have the numbers in front of me but I don't think they are much taller or shorter than the stock tires. If that's the case, then no. No need to change gearing. If they are markedly taller then you could gear down. If shorter, gear up. But I think you are fine ???
