Tire wobbles
Thread starter #1
Brewcity414
King of questions
Likes
111
Wisconsin
Senton
I tried posting a video but I keep getting the error message. I have a horrible rear wheel wobble when driving the truck on the ground. When I sat the truck on the stand and accelerated the tire wobbles horribly. Wonder if I should switch out the axle piece I forgot the official name to the part.
chevys10zr2003
ArrmaForum Fan
Likes
597
Minnesota, USA
Kraton, Senton, Typhon
As of right now I believe you can only link to videos outside of the Arrma forum, such as Youtube. But that feature is in the works. Sorry I'm not able to help with the problem though, but figured I would let you know about the video issue.
need_4_speed
Likes
1
Fazon
You also should check if water got in the tires via holes on the rims. That is a common problem. I regret not to seal all the holes right after I bought all my trucks. Now it is very difficult to get water out, water causes unbalanced tires, then tires wobbles horribly, even damage part due to excessive vibration
Yonic
ArrmaForum Fan
Likes
79
Philly, PA
Senton, Talion, Typhon, Voltage
It could be few things:
- Warped wheel
- sand/water inside the wheel
- damaged bearing
First switch places with another wheel to understand if the problem is in the wheel or the axle.
If it's warped it will wobble in low speed, if it has sand/water it will wobble at high speed only.
After you'll find the cause you'll know how to fix it
Thread starter #7
Brewcity414
King of questions
Likes
111
Wisconsin
Senton
- Warped wheel
- damaged bearing
Thanks I'll try this out.
Yonic
ArrmaForum Fan
Likes
79
Philly, PA
The simplest reason is that the inner wheel have some mud clumps sticking to it, which throw the wheel out of balance. Hard to see on a short course wheel...
And in any case, if you didnt already do so, i would strongly suggest you to vent your tires.
Thread starter #9
Brewcity414
King of questions
Likes
111
Wisconsin
Senton
Thank you much buddy
Don mercier
Likes
26
Senton
Have you tried swapping a front wheel for a back too see if the prob presists? If it dose its prob outer axel spline
TraverseCity420 Wheels & Tires 7
Slicktmi Wheels & Tires 11
thehardway Kraton 7
TraverseCity420 Wheels & Tires 21
Similar threads
