- San Antonio TX
- Felony
- Granite
- Infraction
- Kraton 8S
- Mojave EXB
- Outcast 8s
- Typhon 6s
- Thread starter
- #21
OK. I might do it. Now I just might have to see what I can do with the center diff. I'll probably use brake cleaner instead of the fluid I was using. Even though I've done both. ThanksThe problem is arrmas aluminum diff case. It lacks the 4 keyed pins so the M3.5 diff bolts will take all the load and snap at the head. As others mentioned upgrade to the vitavon V2 diff case, it has 4 pins and M4 screws making it much more durable. Vitavon provided short M4 screws so i used some longer 12.9 grade ones with blue TL as the threads are deep enough.
