Mojave 2WD Tires and wheels
jimbo74
  1. Mojave
I have an original Mojave. The 1/10.
Needs a radio and receiver. No problem, probably going to pick up a $30 Traxxas.
Main issue, is I need wheels and tires. What fits for sure? I can't tell if it needs the same 4 or different offset like a 2wd Traxxas Slash? The hex appears a lot more narrow than the Slash hexes. Also, need new wheel nuts. What fits?
Wow, what a dinosaur.
And still going:p
Is that not a fury bls ? Looks the same as my fury
The Fury and Mojave 2WD were basically the same truck, just different paint scheme and tires.
Slash 2wd wheels work, and so do almost any 1/10TH SCT wheel. I typically run Losi 22S wheels on mine. As for wheel nuts, any shallow NyLock RC nut will work. The longer Traxass ones tend to come loose though. Another option is to use the serrated nuts, since they grab the wheel.
