Why? I kinda get the centre diff but the front and rears i’m Guessing would only break if the left and right tyres were different dimensions. Are you talking about the centre difference? Certainly wouldn’t on a real vehicle unless the differences were extreme maybe?Unless you run a 2wd then don't do that.. your going to spin the diffs at a different speed and they will break when that happens.
Speaking of tires, are there any good non ballooning tires for the Kraton? Can I go a tad bit smaller?
Thank youSearch out 17m Hex tires 3.8" You could go 2.8" if you really wanted to. or even 2.2 SCT. Theres plenty of options to choose from Proline makes some good stuff and there warranty is TOP NOTCH! So if ya bust a tire/s they will replace it free!
I’ve seen people using gorilla tape/locktite glue inside the tires
I blew a tire that came with the kraton. I want to put backflips on it but I only had the money for 2 so what you're saying is I messed up and it won't work.
Its a math problem, Say your rear diff can put out 400Rpm, It can do it even split between left and right or It can do a combo 300 left 100 right, that's how diffs work, But the front and rear must match RPM's in total, left or right don't matter but if you push the rear 300rpm and the front 400rpm with 2 solid axels leading into a center diff that's going to see 2 different speeds its going to shatter.
Center diff can't travel at 300 and 400RPM at the same time its one or the other but you have 2 different rpms fighting to take control and kaboom.
I'm sure theres a better way of explain it as Im trying to pull the explantion that was given to me a while back from memory.. If my internet wuld stop being a pos i'll try and find a better example, But without changing gear ratios inside the diff to compensate then there going to spin at different speeds.
Its even worse with a 3s no center diff just a slipper clutch that long center axel can't spin 2 different speeds you'll break not only the diffs but the axel as well.
