Beastmode1
Hey guys, I was wondering if y’all might know if the black tlr typhon shocks would fit on the typhon 3s. The 6s shocks are out of stock on Jenny’s all the time and I like the black anodized aluminum better. Thanks.
TLR shocks are slightly longer than standard Typhon 6s shocks, but the Mojave shocks you suggested are even LONGER.Not really as they are about 5mm longer and will make your handling fairly bad. You can use nitro tubing and shorten them up but you will have less stroke length.
Fronts are in stock and are normally hard to find :
https://jennysrc.com/collections/ar...ks-assembled-dampers-springs-4mm-hd-ara7604v2
