Typhon TLR vs v5 Center Differential
The only difference between TLR Tuned and v5 is different oil weights.
The TLR should be 100k and the v5 10k stock, if I remember correctly.
The difference in your links is that AR220029 is just the parts for a complete diff, ARA310959 is a pre build and prefilled diff.
Thanks for the info. I was looking at Jenny's RC and could not decide which one to get.
side note - why would arrma fill a center diff for a basher with 10k fluid? I can't image they had visions of it being raced competitively?
10k is probably easier and faster to work with from a manufacturing standpoint.
All of the center 6s diffs, mostly, are 100k & the F&R are 10k. The LSDs are different & so are the the V6, 80k F&R, like the EXB. All my RTR center diffs I've pulled, were half full. F&R were ok.
I should’ve noted that I had the TLR roller. I have some thicker diff fluid but plan on driving it first before making any changes. Still snow covered and freezing here, don’t plan on driving new machine in this.
what electronics did you install in the TLR?
