I took it to the park so I could run it on black top and get my trim set and check motor temps. No fans on the motor yet and after several high speed passes as hot as the motor got was around 160f at the back running the 19t pinion. Only thing I was not too satisfied with was the servo which is a Powerhd-30kg that someone had recommended. In the grass it just does not have the power to get full steering and even on the blacktop it struggled some. I will prob go up to a 50kg or more. Power was great with the hobby wing 1650kv motor on 6s.
