TR2N
You can’t replace only the gears. Replace everything with redcat except ring and pinion.
I am curious but is this the correct set I need to rebuild my Diffs? I have a Kraton v5. Does it fit?
The drive cup is too big for the 43 tooth diff gear!You can’t replace only the gears. Replace everything with redcat except ring and pinion.
You don't have to buy shims there is a video to turn LSD shims and make it openIf you need a beefier ring and pinion, change to the EXB diffs. Make sure to get the 18x20 shims if you want an open diff. LSD is fine for Front and Center too.
I will stick with $1 worth of shims. Not that much of an investment and know they hold up better than someone’s short cut.You don't have to buy shims there is a video to turn LSD shims and make it open
Not to mention eliminating the plates with holes by using shims, to get a “true” open setup.I will stick with $1 worth of shims. Not that much of an investment and know they hold up better than someone’s short cut.
Shortcut ??? Video was uploaded by horizon hobby serviceI will stick with $1 worth of shims. Not that much of an investment and know they hold up better than someone’s short cut.
Hmm what shims are you using for 1us just next time I will buy for replacementI will stick with $1 worth of shims. Not that much of an investment and know they hold up better than someone’s short cut.
I’m curious, do you have a link for that video by chance? I’ve seen several videos covering this, but not from Horizon.Shortcut ??? Video was uploaded by horizon hobby service
I using there method and I have
Oh ok, I’ve seen that one. I didn’t think he discussed open diff though...just the min and max effect LSD. Must have missed that part.
I trying to find it for myself if find it I will post itI’m curious, do you have a link for that video by chance? I’ve seen several videos covering this, but not from Horizon.
I used the “official” method to convert my Kraton EXB’s rear lsd diff to open. You use two of the big beefy shims in the ARA311094 shim set from Arrma to replace the 6 lsd plates in the diff. Running 50k/500k/30k for oil weights.I trying to find it for myself if find it I will post it
I'm only seeming to have problems with the ring and pinion gear, not the internals...so far.
Wondering when m2c gonna start making complete diff setups lo
Did you get a refund on that? I've eyeballed the hot racing stuff though but more metal is more weight and these kratons are already heavy as hell as is.I also found it was far easier to get consistency through the entire rotation when using Hot Racing’s gearboxes.
That said, I did have one HR gearbox that due to variances I found it was impossible to remove play from the input gear alone. Basically after the input gear was installed with the input cup secured, there was play with the diff box. And when I shimmed it to remove this play, the mesh was far too tight when I installed the diff. So this particular HR gearbox ended up being unusable. But this was only on one sample, the others have all been great.
That's not too shabby! Everyone seems to be sold out of everything right now...I didn’t get around to seeing about a refund yet - will try soon.
I also had concerns about weight of these HR gearboxes but then I weighed them and compared with the stock plastic using a baking scale. Turns out the HR gearboxes are only a few grams heavier than the stock Arrma plastic! The difference is negligible.
The HR gearboxes don’t seem to stay in stock longer than a couple of weeks when they become available every couple of months.... I don’t know why these companies don’t do bigger production runs....That's not too shabby! Everyone seems to be sold out of everything right now...
Yes that’s a good point - the HR gearboxes don’t come with the lids, or the sway bar retainers.HR cases need 3 different parts, looks closely. GPM and Vitavon are a full set. Many recommend a seal between chassis and alu case as well. Quality wise they all seem to be adequate with fitment, as above, always being a concern.
Saw a lot of complaints about vivatonI like the look and quality of the HR stuff, I've been buying it like crack, but the Vitavon gearbox bulks look stout and the pinion support bearing is a huge upgrade. At the end of the day, they all cost about the same. I'd like to remove as much flex from my transmission as possible.
