That's a good idea. I will try to keep body tower x brace somewhat together.I had to destroy the X braces in the body tower thing in the middle so the bar would go through there. It's easiest if you take the top off that, remove the x braces, figure out the bar, then put the top piece back on, vs trying to jam it through with the top piece on.
I made a similar one using the @Thomas P videoSame for a Notorious, just shorten the length.
I'm still on the carb load diet, with less air and less breakage but more chips and boozeman im all about that jenny craig plan for my trucks... less breakage and more air...
A pic of the finished product would be nice. Ideas for other members.Just finished my T2T brace on my notorious,used a pc of hardened steel 1/4x5/8 took two notches out to fit over towers and for the middle x brace I just unscrewed the two x braces and folded down. Didn't have to cut.
Here are the picsA pic of the finished product would be nice. Ideas for other members.
The brace ideally should be as low as possible on the rear shock tower.Here are the pics
Personal preference as far as I'm concerned. Put it low if all you want to limit is chassis flex. Put it high if you want to limit chassis flex and having your towers fold in. If I ran non-stock towers, then I'd probably mount mine low.The brace ideally should be as low as possible on the rear shock tower.
Thanks for help, I hope what I did will hold up. Only time will tell.Personal preference as far as I'm concerned. Put it low if all you want to limit is chassis flex. Put it high if you want to limit chassis flex and having your towers fold in. If I ran non-stock towers, then I'd probably mount mine low.
However, I tried running a narrow piece of steel and there are two issues. 1, it's heavy and your putting a lot of weight in the worse possible place, high. and 2, it's too narrow and causes the towers to buckle in the middle pretty easily, then they crack when you straighten them back out.
Use the box aluminum seems to help with both issues. Spreads the load a bit so the tower doesn't buckle in the middle, and it's fairly light.
Thanks for the help, I hope what I did will hold up. Only time will tell.
