Low use. Can be used in a 1/5th scale up to 1/8th. I've got to sell some stuff to make room for the new stuff... $190 buyer pays PayPal fees and I'll split shipping. Since I can get pretty decent rates
Buyer choice 6.5mm bullets or 8mm bullets can be installed for no extra charge. Has 6.5mm currently.
5860 1440kv
Specs
Can: Finned
T: 4D
KV: 1440
Max Amps (A): 441
Max Volt (V): 34
Continuous Power (W): 7200
Max Power (W): 15000
Max RPM: 50 K
Internal Resistance (Ohm): 0.0018
No-load Current (A): 10.9
Shaft Diameter (mm): 8mm
Diameter X Length (mm): 57 X 112
Bolt Pattern: M4*30mm
Weight: 1100 g
Pole: 6-pole
5860 1440kv
Specs
Can: Finned
T: 4D
KV: 1440
Max Amps (A): 441
Max Volt (V): 34
Max RPM: 50 K
Weight: 1100 g
Pole: 6-pole
