Love the new Kraton 6s..mine are bone stock besides T2T brace and 15T pinion
Hi Thomas, great video as always. Those paddle tires really hook up well in the snow. Besides bone stock, did you shim all the diffs in both your new Kraton & Talion?
Stock the Talion is 10,000 front/100,000 center/10,000 rear. The Kraton is 10,000cst front/rear/center. I'm going to try 50,000 front/100,000 center/7,000 rear for my Kraton & the same with my Talion, except I'm wondering if a heavier center fluid of 200,000cst in my Talion would be even a better choice? Arrma uses a heavier center diff fluid in just the Talion, but not sure if this mainly due to it's smaller tires?First off, thanks for the great videos and how to's they have helped tremendously! Much appreciated!
Also, did you change from stock diff fluid....not sure what your definition of stock is and which do you prefer over the other, Kraton or Talion?
Ok, maybe not bone stock, i did shim all ma diffs wich i allways do before a run. The talion im using 16T pinion and its fast as few, the Kraton 15T.
Diffoils Kraton 7k rear 100k mid and 50k front stock shock oil
Talion 7k rear 150k mod and 50k front. I think im arround 8-900 rear and 900 front in shocks . Did the rear arm mod
Hey Thomas. If you just changed the pinions, shimmed diffs & changed oil, I'd say that's still stock, or close enough. Wow, 50ft jumps, pedal to the metal & full throttle on 6S with no upgrades is amazing, GO ARRMA GO. With many of us, this could mean real disaster...
Dang dude, these videos and that play ground is amazing!
